end host discover only MAC Add.
Answered Question
Dec 12th, 2008
I have one a Csisco WS-3750G with 5 blade. any end host attached to this switch. LMS 2.6 end host discovery detect only the MAC address. no Ip address or Host name. anyone know why is that. thank you in Advance.
Correct Answer by Joe Clarke about 8 years 5 months ago
SNMP community strings cannot contain '@', SNMPv3 VLAN contexts must be configured on switches (if using SNMPv3), and SNMP timeouts must be reasonable (e.g. 6 second timeout with 1 retry) in datacollectionsnmp.conf.
The server also needs to have the hardware to support this size network.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 12/12/2008 - 09:32
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
IP addresses are found by polling the ARP tables of routers on the same VLAN as the end host MACs. If those routers are not data collected properly, then no IP address information will show up. Once IPs are acquired, then they will be looked up (i.e. in DNS) to get the hostnames.
eliaspaulos Fri, 12/12/2008 - 10:05
thanks, so do I need a data collection on on the switch again then UT End Host Report? can I able to do UT acquisition on one switch? or should I run on all switch on LMS.because if I run on all it takes more than 24hrs, since we have 50,000 end devices.any short cut?
Joe Clarke Fri, 12/12/2008 - 10:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Once the router is data collected, just run a new UT major acquisition. An acquisition which takes over 24 hours is not right. It sounds like you have SNMP problems, or name resolution issues (if this is Windows).
eliaspaulos Fri, 12/12/2008 - 10:25
Thank you so much J. I did start major acquisition. LMS run on Solaris 8 not windows.SNMP problem on my server side or on device.I have checked UT.log I didn't see any abnormal log. this is like this for long time and I always thought because of we have too many end devices and may be use stand alone CW server. where should I can look for check for the problem?
Correct Answer
Joe Clarke Fri, 12/12/2008 - 10:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
pvanvuuren Sun, 12/14/2008 - 23:10
  • Bronze, 100 points or more
Hi Joe
I would like to ask you what your insight is around (LMS 3.1) User Tracking in a MPLS vpn environment. From what I understand, Campus Manager can collect data from the router and switches, but a end host could possibly stay in its layer 2 environment and never make a request to the router (Layer3). How would one get this end host's IP address? Thanks in advance.
Joe Clarke Sun, 12/14/2008 - 23:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please start a new thread for this question.
