IOS IPSEC VPN with NAT - Translation Problem
Answered Question
I am having with an issue with an IOS IPSEC VPN configuration.
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key TEST123 address 205.xx.1.4
crypto ipsec transform-set CHAIN esp-3des esp-sha-hmac
crypto map CRYPTO-MAP 10 ipsec-isakmp
set peer 205.xx.1.4
set transform-set CHAIN
match address 115
interface FastEthernet0/0
description TO EDGE ROUTER
ip address 208.xx.xx.33 255.255.255.252
ip nat outside
interface FastEthernet0/1
description INTERNAL NETWORK
ip address 10.15.2.4 255.255.255.0
ip nat inside
access-list 115 permit ip 192.xx.xx.128 0.0.0.3 172.xx.1.0 0.0.0.3
(This configuration is incomplete / NAT configuration needed)
Here is the solution I am looking for:
When a session is initiated from the “Internal Network” to the “IPSEC Remote - 172.xx.1.0/30” network I want the “10.15.0.0/16” address scheme to translate to the NAT addresses “192.xx.xx.128/30” before routing over the IPSEC VPN Tunnel.
Please see "ATTACHED DIAGRAM" for more information.
Any help is greatly appreciated!
Clint Simmons
Network Engineer
Correct Answer by rkalia1 about 8 years 3 months ago
Probably you need the following:
ip access-list extended NAT
permit ip 10.15.0.0 255.255.0.0 172.xx.1.0
255.255.255.252
route-map NAT_TO_172.xx.1.0 permit 10
match address NAT
ip nat inside source route-map NAT_TO_172.xx.1.0 pool 192.xx.xx.129 192.xx.xx.130
Correct Answer by Karks Raja about 8 years 3 months ago
You can try the following NAT+route map approach(2nd method in this link)
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
Raja K
Overall Rating: 5 (2 ratings)
Correct Answer
rkalia1 Fri, 12/12/2008 - 12:48
255.255.255.252
match address NAT
Thanks for the response. I did try this approach before. However I will clear the NAT configuration and try again...
ip nat pool CRYPTO-POOL 192.xx.xx.129 192.xx.xx.130 prefix-length 30
ip nat inside source route-map CRYPTO-MAP pool CRYPTO-POOL overload
access-list 115 permit ip 192.xx.xx.128 0.0.0.3 172.xx.xx.0 0.0.0.3
access-list 186 permit ip 10.15.2.0 0.0.0.255 172.xx.xx.0 0.0.0.3
route-map CRYPTO-MAP permit 10
match ip address 186
I will respond with the new results later.
Clint
