CDR for Customer Reports Package
Dec 12th, 2008
Hello all,
I'm trying to pull usage statistics for a 1-800 number that we own. How do I pull this information down from CUCM using the CAR tool? I can't seem to find the right report that gives me what I need. For instance, I'm looking for statistics per day/month that show Attempted Calls, Completed Calls, Percent Complete, etc. We are using CUCM 4.2(3)
Thanks in advance.
Jaime Valencia Fri, 12/12/2008 - 11:29
  • Cisco Employee,
  • Hall of Fame,
    2011
CAR doesn't go that far. it does not have that kind of information natively, it will only show you the calls, not any percentage or completed, etc.
you need a 3rd pary billing SW if you need all that
java
if this helps, please rate
mikechristensen Fri, 12/12/2008 - 11:31
Well honestly, if I could get that, I'd be in good shape. Where can I pull that info from. Not too familiar with CAR yet.
