Packets disapearing after getting unencrypted on IPSEC VPN
Dec 12th, 2008
I am currently having a problem with a VPN that i am setting up and traffic seems to disappear after it is unencrypted. when I ping the from one side of the tunnel to the other and do a show crypto ipsec sa I can see that both of esp SAs are active and that 5 packets have been decrypted. I have also checked the tunnel interface and it shows that no packets have been recieved and when i do traffic export on that interface I not see any traffic coming in. I have setup traffic export on the physical interface to make sure the traffic coming in makes it to the router and I can see ESP packets with the proper SPI coming in. I am not sure what else I can check to view where these packets are getting stopped any ideas?
###### Router 1 ######
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
crypto isakmp key 6 removed address 1.1.1.2
crypto ipsec transform-set MYSET esp-aes 256 esp-sha-hmac
mode transport
crypto map MYMAP 10 ipsec-isakmp
set peer 1.1.1.2
set transform-set MYSET
match address 101
interface Tunnel11
ip address 2.2.2.2 255.255.255.0
tunnel source fastEthernet0
tunnel destination 1.1.1.2
interface Fa0
ip address 1.1.1.1 255.255.255.0
crypto map MYMAP
access-list 101 permit gre host 1.1.1.1 host 1.1.1.2
###### Router 2 ######
encr aes 256
group 2
crypto isakmp key 6 removed address 1.1.1.1
mode transport
set peer 1.1.1.1
match address 101
interface Tunnel11
ip address 2.2.2.1 255.255.255.0
tunnel destination 1.1.1.1
interface Fa0
ip address 1.1.1.2 255.255.255.0
crypto map MYMAP
access-list 101 permit gre host 1.1.1.2 host 1.1.1.1
celiocarreto Tue, 12/16/2008 - 04:30
Hi!
I don't know your IOS Version.
But try such a config (new type of GRE Tunnel):
encr aes 256
group 2
crypto isakmp key test address 1.1.1.1
crypto ipsec profile MYVTI
interface Tunnel0
tunnel mode ipsec ipv4
tunnel protection ipsec profile MYVTI
interface Fa0
Maybe it helps.
pjeunelot Tue, 12/16/2008 - 06:33
I solved this problem. It turned out that the GRE endpoint was assigned to the wrong interface on the second router. I have two inputs to each router and I had the destination of one of the tunnels on an interface that wasn't setup for the VPN. So the packets didn't know where to go after they got decrypted.
