C6509 boot from PCMCIA
Dec 12th, 2008
  • Bronze, 100 points or more
Hi all, I have a Cat6500 x6k-sup2-2ge running an IOS software.
My problem is that I'm stuck in rommon mode after the IOS upgrade. Now I have A PCMCIA and I want to boot a new IOS from the PCMCIA.
I cannot format the PCMCIA from the rommon mode.
How can I format the PCMCIA? The only way is format from a target Catatalyst switch?
All these because I have an error about invalid magic number when I insert the PCMCIA card into the Supervisor2 slot in rommon mode.
Please I need your help,
Thanks in advance.
David
hamismai Fri, 12/12/2008 - 12:55
  • Cisco Employee,
Hi David,
Take the PCMCIA card to another sup2 and format it. Then copy the image from that device or from a FTP Server to the PCMCIA card.
Is there an image on the supervisors 'sup-bootflash: ?
To check see below CLI:
rommon 1 > dev
Devices in device table:
id name
bootflash: boot flash
disk0: PCMCIA Disk 0
Then list the contents of bootflash:
rommon 2 > dir bootflash:
Then:
rommon 3 > boot bootflash:image name
After the image is successfully loaded you can format PCMCIA card and copy the image you need.
For this problem your options are pretty limited.
Hope this helps.
-Hamam
david-lima Fri, 12/12/2008 - 13:01
Thanks a lot Haman, I gonna do that, just this question please:
- is there any problem if I format the PCMCIA from a sup720 or sup (not sup2)?
Thanks a lot again.
David
