Users are not able to connect to WAP
Dec 12th, 2008
Users are not able to connect to 1250 WAP, and getting the below error messages.
Feb 28 20:23:36: %RADIUS-6-SERVERALIVE: Group rad_mac: Radius server 10.138.215.58:1645,1646 is res
ponding again (previously dead).
*Feb 28 20:23:36: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.138.215.58:1645,1646 has returned.
*Feb 28 20:24:23: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.138.215.58:1645,1646 is not responding.
*Feb 28 20:24:42: %RADIUS-3-ALLDEADSERVER: Group rad_mac: No active radius servers found. Id 15.
*Feb 28 20:25:21: %DOT11-4-MAXRETRIES: Packet to client 001f.3cca.f6d1 reached max retries, removing
the client
*Feb 28 20:27:23: %RADIUS-6-SERVERALIVE: Group rad_mac: Radius server 10.138.215.58:1645,1646 is res
*Feb 28 20:27:23: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.138.215.58:1645,1646 has returned.
*Feb 28 20:45:39: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.138.215.58:1645,1646 is not responding.
*Feb 28 20:45:58: %RADIUS-3-ALLDEADSERVER: Group rad_mac: No active radius servers found. Id 20.
*Feb 28 20:48:25: %DOT11-4-MAXRETRIES: Packet to client 001f.3cca.f6d1 reached max retries, removing
the client
Navinder
thompso7540 Wed, 12/17/2008 - 08:37
check to see if you have an entry in your radius server for this AP.
you need to add a new aaa host with teh AP name and bvi IP ....add as RADIUS-AIRONET
what radius server is this? 10.138.215.58
cisco acs? ias? or steelbelted?
SJessulat_2 Thu, 12/18/2008 - 22:54
Hi Navinder,
do You see any messages in the log on the Radius-Server?
On a Cisco ACS, the "Failed Attempts Log" gives You very detailed information on what went wrong. If it states "Unknown NAS", then the suggestion about the missing aaa host is probably right.
Greets,
Sebastian
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
