Warning message
Unity 5 hardware compatibility
Dec 12th, 2008
Although it is not in the hardware compatibility matrix, can Unity 5.0 be installed on an MCS7825-I1 CC1/IPC1
equipped with 2x72 GB drives?
Thanks in advance for any suggestions.
Denis
vhilario Fri, 12/12/2008 - 18:32
Denis:
The only supported platforms for unity 5.0 are the ones that are mention on the following link:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd802132ef.html
MCS-7825-I1-CC1 is for IPCC servers
MCS-7825-I1-IPC1 is for CUCM and NAC APPLIANCE
So you cannot use those servers to install Unity 5.0
Pls rate if this helps
t070335 Fri, 12/12/2008 - 19:20
Thank you very much for confirming what I suspected.
Merry XMas and a Happy New Year
Denis
vhilario Thu, 12/18/2008 - 20:29
No problem any time.
I hope you have also a Merry Xmas and a Happy New Year.
Viri
