CLI commands to backup IOS
Dec 12th, 2008
When backing up the router IOS with the following command: Router# copy flash tftp: The IOS asks for the source file name. What is the correct source file name for the IOS?
Thanks in advance.
Giuseppe Larosa Fri, 12/12/2008 - 11:20
Hello Duane,
the one that is listed in the show ver in the line System Image file
System image file is "flash:c2600-i-mz.122-8.T5.bin"
the part after the : can be enough if your router has only one flash filesystem otherwise you need to use also the part before the :
Hope to help
ropethic Sun, 12/14/2008 - 14:45
After performing the dir flash: be sure to include the directory name in addition to the file name otherwise you will get an error stating this is a directory
copy flash: tftp
tftp ip address:
source file name: dir\filename.bin
destination file name: file.bin
dbdickson Sun, 12/14/2008 - 20:01
Thanks for the help. I have the IOS backed up on my computer.
