Multiple VPN Tunnels between 2 devices
jwilliams
I have a router that has 2 Internet T1 connections. I would like to create 2 tunnels, one on each connection and have them go to a single 7201 in our data center.
1) Is this possible?
2) Is there a way to load balance or bind the tunnels together so that I can utilize the bandwidth from both T1s?
Thanks.
Jason
rkalia1
Not sure if you can do that. However, you can use GRE-in-IPsec type tunnel and use EIGRP to failover in case on ISP link fails. It may not be possible to use both the tunnels at the same time as the source and destination networks are same for both the tunnels.
