Need "port Link status" to log to buffer- Cat IOS 12.2-20
dmooreami
Level 3
Level 3
What am I missing. I don't see my cat4006 ports going up/down in any of my logs as pc's are connected, or powered off.
Want to see the fastE ports connecting/disconnecting so I can verify and locate PC quickly that don't have correct IP's, etc.
I have logging set to debugging, etc.
thanks
6 Replies 6
glen.grant
Make sure you have the command , "logging event link-status default " implemented .
command not present in Cat IOS 12.2(20)
Sorry that is a 6500 , of course they wouldn't be the same . :-) try adding snmp-server enable traps command.
Nope, all snmp traps are enabled. I get vty messages logged.
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns)
Console logging: level debugging, 15 messages logged
Monitor logging: level debugging, 3 messages logged
Buffer logging: level debugging, 40 messages logged
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Trap logging: level debugging, 45 message lines logged
Logging to 192.168.99.15, 45 message lines logged
"logging event link-status default"
This command is available for 4000/4500 but you need release 12.25(SG) minimum to run it -
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25sg/command/reference/int_sess.html#wp2089249
Jon
good to know, but stuck with 12.2-20 for now.
I can't believe that the port up/down status don't "log" into the system by default. Hell, a 2900 series does this by default. as do any of the CatOS rev's. Most times I need to turn if off, not on.
