Speech Connect - No network Connectivity
Dec 13th, 2008
Has anybody installed Speech Connect and have failed Network Connectivity, even though the application is running finr, the configuration of the Network Settings are correct and the NIC is "lit" on the server? I have also tried using the second NIC on the MCS-7845, still no IP connectivity...
Kevin Porter Sat, 12/13/2008 - 14:32
Had to Re-install from scratch. The original License key from the server was exactely the same after a re-install, so the original License Key received from "sc-licensing" was still good.
