Speech Connect - Upgrades
Dec 13th, 2008
I have just installed Speech Connect with version 1.0.1 and version 1.0.3 is available. The Install and Admin guide says "upload upgrade file via sFTP to the /tmp directory", how or where do you go to perfrom this "upload"?
Kevin Porter Tue, 12/16/2008 - 11:22
You must have an sFTP server running somehwere, and set the root directory to where the Upgrade file is located then:
Open SSH V2 connection to server console
login with: scadmin
enter: cd /tmp
enter: sftp (username)@:
enter: su -
enter the root password
enter: mv /tmp/ /common
enter: cd /common
enter: sh ./
