EIGRP - unwanted routes
Answered Question
Dec 13th, 2008
I have Telco MPLS CE router connected to my C4506 (L3) interface. I can see on my C4506 many unwanted routes distributed by Telco through this interface. Most of them are public IP addresses (they use them for loopbacks IPs). To avoid any routing problems in the future I want to stop distributing these IP addresses to my network. I built "access-liststandard DENY_TELCO_LOOPBACK" and then I applied this list under EIGRP using "distribute-list DENY_TELCO_LOOPBACK in".
It didn't stopped these routes from being distrubuted at all. What wrong I am doing? Is there any better way of doing this?
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
Hello Rick, Zbigniew
to reference the route-map you need
distribute-list route-map rm-filter-telco-loops in gi6/32
the route-map keyword has to be specified or the router will look for a named ACL with name rm-filter-telco-loops that of course does not exist and no route filtering action occurs
I'm sorry I didn't see this before
ge 32 means only prefixes with len >= 32 that is not what you want keep le 32 that will match whatover prefix len /29, /30, /27 within the IP address block
OR if the distribute-list supports refers directly to the prefix-list as Rick has suggested
Hope to help
Giuseppe
Correct Answer by Richard Burts about 8 years 5 months ago
Zbigniew
There is a slight difference in syntax when the distribute list will be using a prefix list instead of a more normal access list. I suggest that you change this:
distribute-list RM-FILTER-TELUS-LOOPS in GigabitEthernet6/32
to this:
distribute-list prefix RM-FILTER-TELUS-LOOPS in GigabitEthernet6/32
try it and let us know if it works better.
Rick
Overall Rating: 5 (2 ratings)
Richard Burts Sat, 12/13/2008 - 19:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
zbigniew
I believe that you are going in the right direction. A distribute list under EIGRP using a standard access list is typically the best way to prevent certain routes from being accepted into EIGRP. Perhaps there is some small issue with syntax or something that is preventing it from working as you want it to. Perhaps you could post the specifics from the config and we might be able to identify the issue.
Rick
zbigniewkozyra Sat, 12/13/2008 - 20:18
Thank you for your reply
Here is a part of config and some of unwanted routes which I want to filter:
ip access-list standard DENY_TELUS_LOOPBACK
deny 10.52.0.67
deny 154.11.18.0
deny 206.75.127.0
permit any
router eigrp 100
redistribute static
passive-interface default
no passive-interface Vlan100
no passive-interface GigabitEthernet6/32
no passive-interface GigabitEthernet6/47
network 10.0.0.0
distribute-list DENY_TELCO_LOOPBACK out GigabitEthernet6/32 ****
distribute-list DENY_TELCO_LOOPBACK in GigabitEthernet6/32
distribute-list 93 out GigabitEthernet6/47
distribute-list DENY_TELCO_LOOPBACK out ****
**** I put "in" and "out" just in case. I think I should use "distribute-list DENY_TELCO_LOOPBACK in GigabitEthernet6/32" only
D EX 206.75.127.248/29
[170/256512] via 10.80.6.6, 00:01:45, GigabitEthernet6/32
D EX 206.75.127.240/29
D EX 206.75.127.232/29
chintu_punjabi Sat, 12/13/2008 - 22:44
Is it a typo;
Access-list is of name " DENY_TELUS_LOOPBACK "
and in eigrp config, access-list called is "
DENY_TELCO_LOOPBACK ".....
Hope to help
zbigniewkozyra Sat, 12/13/2008 - 22:59
It is actually not a typo. For a conversation purpose I wanted to change a name of an access-list before posting it here but I changed only one name and didn't the second one.
In my config both names are DENY_TELUS_LOOPBACK
chintu_punjabi Sun, 12/14/2008 - 01:39
- Can you post the ouput of show eigrp topology here ?
- Are you seeing any hits on access-list ?
Hope to help
Giuseppe Larosa Sun, 12/14/2008 - 04:05
  • Hall of Fame,
    Founding Member
Hello Zbigniew,
a standard ACL when applied for filtering routes works only on exact matches.
So it would require a long list with one line for each unwanted subnet.
If you have a lot of /29 within an ip address block you should use a prefix-list or an ip extended ACL.
I think the prefix-list it's easier to use and I provide you an example
ip prefix-list filter-telco-loops deny 206.75.127.0/24 le 32
a line like this denies any possible subnet of block 206.75.127.0/24
you need the equivalent of permit ip any any
ip prefix-list filter-telco-loops permit 0.0.0./0 le 32
then you apply it adding the prefix-list
in a route map
route-map rm-filter-telco-loops permit 10
match ip address prefix-list filter-telco-loops
the route-map can be invoked by the distribute list command
router eigrp 100
see
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_pi1.html#wp1018093
This should fix your issue. Add statements before the final permit to deny all other unwanted IP blocks
Hope to help
Giuseppe
zbigniewkozyra Sun, 12/14/2008 - 10:29
Thank you very much for an advice. I will try your solution. I think you are right because I can see hits in access-list if the access- list is very specific. for example:
if I have deny 10.52.113.117 then I see hits, but when I have deny 154.11.18.0 then there are no hits at all.
Thanks again
Richard Burts Sun, 12/14/2008 - 17:45
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
zbigniew
Giuseppe is giving you good advice. From the perspective of the access list (and distribte list) there must be an exact match between what is stated in the access list and the prefix that is being advertised. I can see from your perspective that you would like to identify an address block and to deny all subnets contained within it. The tool that can do that is prefix lists, as Giuseppe has suggested.
This is why the access list and distribute list that you have configured are not working as you want. If you change the configuration and use prefix lists it should accomplish what you want.
Rick
zbigniewkozyra Sun, 12/14/2008 - 21:24
I did what Giuseppe sugested:
router eigrp 100
redistribute static
network 10.0.0.0
ip prefix-list FILTER-TELUS-LOOPS seq 5 deny 206.75.127.0/24 le 32
ip prefix-list FILTER-TELUS-LOOPS seq 10 permit 0.0.0.0/0 le 32
route-map RM-FILTER-TELUS-LOOPS permit 10
match ip address prefix-list FILTER-TELUS-LOOPS
but I still see routes to network 206.75.127.0/24
I replied to Guiseppe as well
Giuseppe Larosa Sun, 12/14/2008 - 23:58
  • Hall of Fame,
    Founding Member
Hello Zbigniew,
two suggestions:
a) the command could be given without providing an interface
b) after making a change you may need to use commands like clear ip route * or
clear ip eigrp 100 neighbor
and then later see if you achieved the desired results
Also you can check if the prefix-list has matched with
show ip prefix-list FILTER-TELUS-LOOPS
if no matches appear for the deny statement we need to consider another solution
If you like you can post
sh ip route | inc 206.75.127.
Hope to help
Giuseppe
zbigniewkozyra Sun, 12/14/2008 - 21:21
I did what you suggested:
router eigrp 100
redistribute static
network 10.0.0.0
I still see routes 206.75.127.0/24
Didi I miss something?
chintu_punjabi Sun, 12/14/2008 - 22:25
Either you can make an access-list to exactly match 206.75.127.232/29, 206.75.127.240/29. 206.75.127.248/29....
or
make your prefix-list as:
ip prefix-list FILTER-TELUS-LOOPS seq 5 deny 206.75.126.0/23 ge 32
ip prefix-list FILTER-TELUS-LOOPS seq 10 permit 0.0.0.0/0 ge 32
It will work..
Hope to Help
zbigniewkozyra Mon, 12/15/2008 - 05:56
Should it be "le 32" as suggested by Giuseppe or "ge 32" as you suggested. Giuseppe specified 206.75.126.0/24 and you specified 206.75.126.0/23.
I tried both and still doesn't filter this route.
Correct Answer
Richard Burts Mon, 12/15/2008 - 08:54
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Zbigniew
to this:
Rick
Correct Answer
Giuseppe Larosa Mon, 12/15/2008 - 10:22
  • Hall of Fame,
    Founding Member
Hope to help
Giuseppe
zbigniewkozyra Wed, 12/17/2008 - 05:18
Thank you very much for your help. It works. I didn't finish configuration yet because we have a "freeze" on network changes but I filtered one route and it works.
Richard Burts Wed, 12/17/2008 - 10:38
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Zbigniew
I am glad that our responses helped you solve your problem. Thank you for using the rating system to indicate that your problem was resolved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that they will read responses which did lead to a solution.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
