How to install GNS3 on Ubuntu 8.10??
Dec 14th, 2008
Does anyone share any information about how to install GNS3 on unbuntu 8.10...
I'm using Ubuntu/Linux for the first time and have no idea how to run the setup of GNS...
Pls help..
Thanks & Regards,
CM
Collin Clark Mon, 12/15/2008 - 07:15
You can also open a terminal and type
sudo apt-get install gns3
It will prompt you to install all the dependencies, choose Y. Once done, you should be good to go.
