Can Cisco Router support multiple PPPoE connection?
Dec 14th, 2008
Dear all,
If yes, can it also support load-sharing for outgoing support to different PPPoE connection?
Eric
Giuseppe Larosa Sun, 12/14/2008 - 04:20
  • Hall of Fame,
    Founding Member
Hello Eric,
in 12.4T support for multiple PPPoE clients over the same ATM/ADSL interface has been introduced
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t15/mpppoec.html
if instead you want to use multiple DSL lines you can follow the suggestions of the previous post: you define a dialer interface for each DSL interface.
The more difficult part can be NAT configuration.
Routing redundancy is as simple as adding a second defaul static route
Hope to help
Giuseppe
eric.huihk Sun, 12/14/2008 - 07:31
Thanks for your prompt reply. It is very helpful.
Besides, do you know if Cisco ASA also have such features?
Eric
