Dec 14th, 2008
I have a 2621XM router and I need to config the it for PPPOE for my AT&T service. Will the config below work for me? I only have Fastethernet interfaces on this router. Also where do I type my username and password for the PPPOE login to the internet service.
hostname pooh
ip host rund
ip subnet-zero
no ip domain-lookup
vpdn enable
no vpdn logging
vpdn-group 1
protocol pppoe
interface Ethernet0/0
ip address
ip nat inside
no ip mroute-cache
interface Ethernet0/1
no ip address
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip nat outside
ip mtu 1492
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username cisco password cisco1
ip classless
no ip http server
dialer-list 1 protocol ip permit
ip nat inside source list 1 interface Dialer1 overload
ip route dialer1
access-list 1 permit
line con 0
exec-timeout 0 0
transport input none
line vty 0 4
password ww
Laurent Aubert Sun, 12/14/2008 - 12:33
If you don't know the authentication protocol your ISP is expecting, configured both (PAP and CHAP)
Also you usually don't authenticate the ISP device so the config should looks like this:
interface Dialer 1
ppp authenticate pap chap callin
ppp chap hostname cisco
ppp chap password cisco1
Replace cisco/cisco1 by your login credentials received from your ISP
Troubleshooting links:
(just replace the ATM interface by your Fast interface)
Hope this helps
