ISIS over Frame Relay, Router 1750
Dec 14th, 2008
A quick question, I'm trying to run IS-IS over frame relay studying for my CCNP on a Cisco 1750 Ver 12.1,
The "Router isis" command doesn't put me in the router config mode, does it mean that ISIS is not supported on this router ?
pkoritsas Mon, 12/15/2008 - 19:33
I ran in to a similar problem myself in my studies a few weeks ago. You can tab the is-is commands but when you hit enter nothing happens.
You need a later IOS (12.3 I think)
Check out http://tools.cisco.com/ITDIT/ISTMAIN/servlet/index (search by product) to find out which release is most appropriate.
I hope that helps!
Phil
sergeimavashev Tue, 12/16/2008 - 08:48
I quick question, do you have to pay to download the latest IOS ? Because I find it, but can't download it.
