about the short cut to dial number on Cisco IP phone 7970, 7960 or 7940
Answered Question
Dec 14th, 2008
Just wonder if there is a way to have the cisco IP phone store the history of what previously has been dialed and enable us to dial it faster if we have to dial it again next time.
e.g. if I have previously dialled 62434801, 62435151 and 62435106. When I begin to dial 6243 it will show me all three of the above numbers but if I proceed to type 62435 it would now only show me 62435106 and 62435151.
Kinds regards
Rachel
Correct Answer by Rob Huffman about 8 years 7 months ago
Hi Rachel,
This should be built-in already :) Just try dialing with the Handset "on-hook" and these previously called numbers will show on screen and can be selected and dialed just like you are looking for. This doesn't work if the Handset is "off-hook".
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Sun, 12/14/2008 - 14:56
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rachel,
Hope this helps!
Rob
rachelau_2005 Sun, 12/14/2008 - 14:59
Hi Rob,
I tried it and it works :) Thanks so much for your help again!!!
Kind regards
Rachel
Rob Huffman Sun, 12/14/2008 - 15:06
  • Hall of Fame,
    Founding Member
Hi Rachel,
You are most welcome my friend! Glad to be of some small help here.
Cheers!
Rob
