Username in Console of 3750 Switch
Answered Question
Dec 14th, 2008
Hi all,
Good day.
How can I create an account in console line of 3750? How can I disconnect users that are currently shown in Show users command?
Something like this:
Line User Host(s) Idle Location
1 vty 0
Thanks in advance.
regards,
Gagamboy
Correct Answer by johnlloyd_13 about 8 years 4 months ago
yes i am! Ü
Overall Rating: 4.5 (2 ratings)
johnlloyd_13 Sun, 12/14/2008 - 22:15
  • Blue, 1500 points or more
you can use the either the local or tacacs login for console line.
Router(config)#line console 0
Router(config-line)#login ?
local Local password checking
tacacs Use tacacs server for password checkin
for local, create a local user database
Router(config)#username privilege 15 password
for tacacs, you need AAA (local database for secondary authenticatio if tacacs doesn't work) and tacacs server host configured:
Router(config)#aaa new-model
Router(config)#aaa authentication login default group tacacs+ local
Router(config)#tacacs-server host
To disconnect or "kick" users, do a clear line and choose which connection to disconnect
Router#clear line ?
<0-6> Line number
async-queue Clear queued rotary async lines
aux Auxiliary line
console Primary terminal line
vty Virtual terminal
gagamboy15 Mon, 12/15/2008 - 17:03
That is great. Thanks John. I believe you are a Filipino? :-)
regards,
Gagamboy
