class-map config with asterisk (*)
Answered Question
Dec 15th, 2008
  • Blue, 1500 points or more
all,
in the configuration of class-map with expressions, what are the differences between placing the asterisk (*) on the examples below?
class-map class1
match protocol http mime "*.jpeg"
class-map class2
match protocol http host cisco*
class-map class3
match protocol fasttrack file-transfer "*cisco*"
Correct Answer by royalblues about 8 years 6 months ago
All http mime files having an extension *.jpeg will be matched
Will match the http packets with the hostname string. The * at the end of the string match cisco at the beginning of the string
This matches all the fast track protocols with the character Cisco. * at both ends means match if it is present anywhere in the string
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Mon, 12/15/2008 - 01:28
  • Green, 3000 points or more
Narayan
