Clear ciso IP phones calls history centerally from the call manager
Jaime Valencia Mon, 12/15/2008 - 09:17
  • Cisco Employee,
  • Hall of Fame,
    2011
we do not have an interface or tool for that, you can simply shut down the switch ports to achieve this since the info is not saved if the phone has a power interruption
java
if this helps, please rate
Sascha Monteiro Tue, 12/16/2008 - 23:26
  • Silver, 250 points or more
You could send an ipphone execute with the following URI: Init:CallHistory
You should get the ip-addresses of your phones via axl risport, or use jtapi xsi to send the command.
this would work only on the 7941 however
