12-15-2008 01:30 AM - edited 03-06-2019 02:58 AM
In my router there are many multilink interfaces used to connect remote offices.
I configure each multilink interface with 30-bit subnet mask.When using the command "show ip route", there are not only
C x.x.x.0/30 is directly connected, MultilinkXX
but also
C x.x.x.2/32 is directly connected, MultilinkXX
in the list.
Why the connected route with 32-bit network is in the list?
Solved! Go to Solution.
12-15-2008 01:39 AM
When you use PPP encapsulation, IOS by default would install a /32 route in the RT
To remove this route use the command under the interface
no peer neighbor-route
http://www.cisco.com/en/US/docs/ios/12_0/dial/configuration/guide/dcppp.html#wp4246
Narayan
12-15-2008 01:39 AM
Narayan
