point to point connectvity
Dec 15th, 2008
Problem Details: iam having 1841 router in main office, isp connected s0/0, s0/1 ip
10.10.10.1 and e0/0 is connected to my proxy server(192.168.0.1), from that it is going
my lan. now i want to extend 192.168.0.0 network to my branch office. This is only point to point conectivity intranet and internet purpose. In remote side s0 ip 10.10.10.2/24.and Lan ip 192.168.3.1.
Giuseppe Larosa Mon, 12/15/2008 - 01:48
Hello Ramnet,
you have a point-to-point serial connection between main site router 1841:s0/1 ip 10.10.10.1
If you had more powerful routers involved from 2811 and above you could think to use L2TPv3 to transport ethernet frames inside IP packets.
If you use Frame-relay on the point-to-point you could use bridging over the wan
http://www.cisco.com/en/US/docs/ios/12_0/ibm/configuration/guide/bctb.html#wp4865
But be aware that in any case extending a vlan over a T1 link with routers like yours can be an issue for different reasons: broadcast control, security and performances.
I recommend considering alternate options that allow to use a routed solution
Hope to help
Giuseppe
ramnet communic... Mon, 12/15/2008 - 05:20
Dear,Giuseppe
we dont want frame realy connection between two routers we want point to point connection trough encap ppp only remote side router 2500 series router .and main office also i think 2600 series router.so plz advise to main office to remote office internet and intranet connectvity.solution.
Giuseppe Larosa Mon, 12/15/2008 - 21:50
Hello Ramnet,
I would use PBR on the link to the branch office to redirect traffic to the proxy server that if I've understood correctly is the reason you want to extend that vlan.
Another option could be the use of NAT
the PBR could use an extended ACL to redirect to the proxy traffic with source = branch and destination different then HQ subnets
access-list 121 deny ip 10.0.10.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 121 permit ip 10.0.10.0 0.0.0.255 any
route-map pbr_rm permit 10
match ip address 121
! ip address of proxy here
set ip next hop 192.168.0.1
int ser0/1
ip policy route-map pbr_rm
The suggestion is that you don't need to extend a Vlan to use a proxy.
Hope to help
Giuseppe
ohassairi Mon, 12/15/2008 - 22:14
i will suggest to change topology:
i suppose you have 2 NIC in your proxy: one goes to lan and the second goes to rtr.
just use only one NIC , connct it to LAN.
connect also the rtr to LAN.
users in remote site will use the proxy like any other PC in main office.
you can also add an CAL in the rtr to permit only the proxy to go to internet.
ohassairi Fri, 12/19/2008 - 10:24
as i said you should chabge your design because your proxy has a public IP. this makes it unprotcted from internet.
keep the proxy connected only to lan.
lets suppose it has the ip 192.168.0.100
just configure your rtrs af follow:
branch:
interface ether1
ip address....
interface s0
ip addre ....
encapsulation PPP
ip route 192.168.0.0 255.255.255.0 s0
main office
interface ether1
ip address 202.65.147.193 255.....
ip address 192.168.0.254 255.255.255.0 second
ip nat inside
interface s0
ip addre ....
encapsulation PPP
interface s1
ip addre ....
encapsulation PPP
ip nat outside
access-list 1 permit host 192.168.0.100
ip nat inside source list 1 interface ether 1 overload
ip route 192.168.3.0 255.255.255.0 s0
ip route 0.0.0.0 0.0.0.0 s1
now in browser (from both sides) define your proxy:192.168.0.100/8080
note: in the future don't publish your real IP in diagrams. this give to hackers apportinuty to attack your public servers.
hope this help
