anyconnect and password renewal
Dec 15th, 2008
Hi, is there a way to force a periodic password renew with Anyconnect through ASA and ACS ?
thank you in advance
Anonymous (not verified) Mon, 12/22/2008 - 14:59
AnyConnect does not have any option inside of it to trigger or initate a password change. Password changes are only triggered from the head-end when required as part of MSCHAPv2 RADIUS with expiry or Lightweight Directory Access Protocol (LDAP) password expiration. Customers can change their Active Directory (AD) password using the same ctrl-alt-del mechanism assuming they are 'logging in to the network' (Start Before Login).
AnyConnect VPN Client FAQ:
