Catalyst 6506E not booting
Answered Question
Dec 15th, 2008
Hi all,
We have purchased 2 6506E switches for our new branch. The problem is that one of them does not boot and it enters rommon instead. You have to force it to boot using the boot command in rommon every time it needs reboot. Below are boot configs from the switch.
6506-01#sh run | i boot
boot-start-marker
boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI.bin
boot-end-marker
6506-01#sh boot
BOOT variable = sup-bootdisk:,1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby is not up.
6506-01#dir sup-bootdisk:
Directory of sup-bootdisk:/
1 -rw- 33554432 Dec 15 2008 08:19:58 +00:00 sea_console.dat
2 -rw- 33554432 Oct 7 2008 17:08:20 +00:00 sea_log.dat
3 -rw- 97119716 Dec 15 2008 08:00:56 +00:00 s72033-ipservicesk9_wan-mz.122-33.SXI.bin
I have tried to upgrade the IOS on both switches but the problem did not clear on the switch.
Any idea please.
Best regards,
Stanslaus.
Correct Answer by Mark Yeates about 8 years 2 months ago
I am still unsure why the boot variable is not changing. Try rebooting the switch and change the config register in rommon and see if that helps. When you are in rommon type "confreg 0x2102" and hit enter and then type "reset" That will reboot the supervisor. Are you just typing "boot" in rommon or are you specifying the full directory and filename?
HTH,
Mark
Your current boot variable is set to sup-bootdisk:
no boot system flash bootdisk:
boot system flash bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI.bin
save the config, reboot... If this doesn't work please post the output of "show version" and "show boot" commands.
Mark
Overall Rating: 5 (2 ratings)
Mark Yeates Mon, 12/15/2008 - 06:03
Stanslaus,
Based on the output of the show boot command it does not indicate that you have specified an IOS to boot. Add this to your config and save then reboot.
HTH,
Mark
IT_Data_CorporateNet Mon, 12/15/2008 - 06:56
Thanks Mark,
The command is there already. See on my show run | i boot command. It is strange to me that the IOS does not appear on the show boot command. The IOS is installed on sup-bootdisk: of the supervisor engine.
regards
Stanslaus.
Correct Answer
Mark Yeates Mon, 12/15/2008 - 07:39
Mark
IT_Data_CorporateNet Mon, 12/15/2008 - 08:04
Still going to rommon.
6506-01#sh boot
BOOTLDR variable =
Standby is not up.
6506-01#sh version
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 07-Nov-08 04:01 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
6506-01 uptime is 4 minutes
Uptime for this control processor is 5 minutes
Time since 6506-01 switched to active is 3 minutes
System returned to ROM by reload at 15:49:01 UTC Mon Dec 15 2008 (SP by reload)
System image file is "sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6506-E (R7000) processor (revision 1.1) with 983008K/65536K bytes of memory.
Processor board ID SAL12405T65
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
14 Virtual Ethernet interfaces
51 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Stanslaus.
Correct Answer
Mark Yeates Mon, 12/15/2008 - 08:27
HTH,
Mark
IT_Data_CorporateNet Mon, 12/15/2008 - 09:00
Great!!!!
It resolves the problem. It is now booting without entering rommon after reset. The sh boot output still doesn't show the IOS but this is not a problem as the other switch was giving the same output. Thanks very much Mark!
I also have another scenario on another site which has also being a big problem to me for a long time.
I have this situation.
Three server farm, each with two real server, which should be accessed by their Virtual IP addresses in their respective ports, i.e. client request should be natted by the SLB to correspond to the real servers. This means that, clients are in different VLANs from the one with real servers. So clients connects by using Virtual IP addresses, and expected to be natted to the real one. Below is the sample of my configurations;
Server Farm Configurations
ip slb serverfarm SF_1
nat server
access Vlan21
real 10.152.1.69
weight 1
faildetect numconns 1 numclients 1
inservice
real 10.152.1.70
weight 1
inservice
Virtual Server Configurations
ip slb vserver VS_TCP1
virtual 10.154.0.47 udp 69
serverfarm SF_1
access Vlan1
replicate casa 10.200.0.13 10.200.0.14 1026 password xxx
inservice standby FW_Side
Now with this configuration, i need to achieve two things;
1. The virtual server needs to be configured to connect to the couple of ports with only one Virtual IP address.
2.The clients, who are in VLAN one, should use the virtual IP address, i.e. 10.154.0.47, to connect to the real servers in ports 20/21, 25 and 69 and any other specified after step one is configured for the couple of ports.
If you have any Idea please.
Again thanks very much for your support.
Best regards,
Stanslaus.
Mark Yeates Mon, 12/15/2008 - 09:10
I am glad I was able to help you with this. I would start a new thread on this issue as I am not too knowledgeable on that particular subject. The server networking forum would be the best place to post this question.
Mark
glen.grant Mon, 12/15/2008 - 08:28
More than likely the config register is wrong on either the layer 2 supervisor or the layer 3 msf . Verify once its booted up that both the l2 supervisor config register is 0x2102 and the msf is also 0x2102 , my guess is that one is incorrect , we have seen this right from the factory . From the msf try "remote command switch show bootvar " and check the register.
