Flash Card issue with 6509
rmishra22
Just finished installing 512 MB of fash card in our 6509E'S, FORMATTED but following output puzzles me .. kindly help!
xxxxxxxx#dir
Directory of disk1:/
No files in directory
522903552 bytes total (0 bytes free)
11 Replies 11
Mark Yeates
Level 7
Level 7
Rajiv,
A freshly formatted card will not have any files on the disk. This is normal. You will need to copy an IOS to the flash card. This guide should help you be able to do that.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080116ff0.shtml#sup720catos
HTH,
Mark
Thanks Mark,
I am sory but you ignored the fact that the newly formatted flash card with "no" files on it says "0 bytes free".
Also, the tftp transfer will not happen with error "no space" ( which as per the dir output is obvious)".
Let me know if you have any more ideas.
thanks
Sorry I completely missed the fact that there were 0 bytes free. Was the card formatted in the same device you are trying to use it in? What brand CF are you trying to use?
Mark
Thanks Mark,
Now you are on the right track.
The cards are from cisco and they have been formatted on the same 6509E from where i took this output.
I am curious to know whats wrong?
regards
That is strange and have never seen that happen before. Can you try the other Compact flash slot and format it again and see if that works. There is a possibility that the card may have gone bad or is defective.
Mark
xxxxxxxxxxxxxx#dir disk0:
Directory of disk0:/
522903552 bytes total (522903552 bytes free)
xxxxxxxxxxxxxx#
xxxxxxxxxxxxxx#
xxxxxxxxxxxxxx#
xxxxxxxxxxxxxx#
xxxxxxxxxxxxxx#copy tftp
xxxxxxxxxxxxxx#copy tftp: disk0:
Address or name of remote host []? 10.157.248.93
Source filename []? s72033-adventerprisek9_wan-vz.122-33.SXH3a.bin
Destination filename [s72033-adventerprisek9_wan-vz.122-33.SXH3a.bin]?
Accessing tftp://10.157.248.93/s72033-adventerprisek9_wan-vz.122-33.SXH3a.bin...
Loading s72033-adventerprisek9_wan-vz.122-33.SXH3a.bin from 10.157.248.93 (via Vlan901): !
%Error opening disk0:/s72033-adventerprisek9_wan-vz.122-33.SXH3a.bin (TF I/O failed in data-in phase)
Address or name of remote host [10.157.248.93]?
Source filename [s72033-adventerprisek9_wan-vz.122-33.SXH3a.bin]?
%Error copying tftp://10.157.248.93/s72033-adventerprisek9_wan-vz.122-33.SXH3a.bin (Not enough space
xxxxxxxxxxxxxx#format disk0:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "disk0:". Continue? [confirm]
Format: Drive communication & 1st Sector Write OK...
Writing Monlib sectors..................................................................................
Monlib write complete
Format: All system sectors written. OK...
Format: Total sectors in formatted partition: 1021941
Format: Total bytes in formatted partition: 523233792
Format: Operation completed successfully.
Format of disk0 complete
xxxxxxxxxxxxxx#
xxxxxxxxxxxxxx#
xxxxxxxxxxxxxx#
Is this a new CF card? It is possible that the card is faulty. Have you tried a different slot or different switch/supervisor to try to format the card?
Mark
I am facing the same problem with 4507   6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E .
xxxxxxxx#sh bootflash:
-#- --length-- -----date/time------ path
1 25005209 Feb 25 2012 05:40:32 cat4500e-entservices-mz.122-54.SG1.bin
2 25936915 Jul 11 2013 03:29:36 cat4500e-entservicesk9-mz.122-54.SG1.bin
0 bytes available (131436544 bytes used)
Both the files are corrupted and now i want to format the Boot flash and copy IOS.
delete bootflash:/cat4500e-entservices-mz.122-54.SG1.bin
Delete filename [cat4500e-entservices-mz.122-54.SG1.bin]?
Delete bootflash:/cat4500e-entservices-mz.122-54.SG1.bin? [confirm]
%Error deleting bootflash:/cat4500e-entservices-mz.122-54.SG1.bin (TF I/O failed in data-out phase)
xxxxxxxx#delete bootflash:/cat4500e-entservicesk9-mz.122-54.SG1.bin
Delete filename [cat4500e-entservicesk9-mz.122-54.SG1.bin]?
Delete bootflash:/cat4500e-entservicesk9-mz.122-54.SG1.bin? [confirm]
%Error deleting bootflash:/cat4500e-entservicesk9-mz.122-54.SG1.bin (TF I/O failed in data-out phase)
xxxxxxxxx#format bootflash:
Format operation will destroy all data in "bootflash:". Continue? [confirm]
Format of bootflash complete
xxxxxxxxx#
xxxxxxxxx#
xxxxxxxxx#sh bootfla
xxxxxxxxx#sh bootflash:
I could neither delete nor format the boot flash ..
the same thing with CF ..
please suggest.
Could you give squeez disk0: and check.
Chao
Vishwa
sorry, there is no squeeze for disk0 or 1.
Are you certain the issue is related to the flash module and not a result of the size limitation with TFTP transfers? Try doing the transfer with FTP.
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
