3750 SMi to EMi upgrade
Answered Question
Dec 15th, 2008
I'm trying to upgrade a 3750G-12 from ipbase to ipservices and get this message whilst trying:
Error: The image in the archive which would be used to upgrade
Error: system number 1 does not support the same feature set.
Any idea why its happening and how I get round the problem?
Correct Answer by royalblues about 8 years 1 month ago
Usr the /allow-feature-upgrade parameter to the archive download-sw command and you should be ok
This error comes when you are trying to upgrade to a new feature set in the IOS
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Mon, 12/15/2008 - 05:40
Narayan
