ACS Shell Command Authorizations Set
Dec 15th, 2008
I have Cisco ACS Server V4.0
In the shell Command Authorization Set I configure a restrict Access.
In the privilege mode the restriction of the commands works good, but when I enter in the config prompt the restriction don't works. In this promt I can enter all commands.
Why This?
Collin Clark Mon, 12/15/2008 - 06:14
  • Purple, 4500 points or more
It's probably misconfigured somewhere.
wilnil123 Mon, 12/29/2008 - 11:36
I have the same error with ACS Server 4.2. I can restrict in privilege mode but global config is wide open. Also any command i block in privilege mode can still be executed in global config using the "do" command. How do i block that, or find out what commands the router is sending to the ACS.
Jagdeep Gambhir Mon, 12/29/2008 - 12:23
  • Red, 2250 points or more
Hi All,
Please paste the aaa commands and also make sure you have this command
" aaa authorization config-commands"
~JG
