Warning message
Mars Raid-10 status degraded
Dec 15th, 2008
My CS-Mars 110 had crashed for some unknown reason. After reload the device works fine but there is an error with the raid-10 which shows a status of "Degraded", please see attached file.
Is there a way to solve this problem?
krir Mon, 12/15/2008 - 07:52
  • Cisco Employee,
I am not able to open the attachment, could you paste the output directly instead of attaching the file
It could be coz of the failure of one of the HDD. Raidstatus will show you which HDD is not working. Replace the HDD ASAP
Farrukh Haroon Mon, 12/15/2008 - 22:57
  • Red, 2250 points or more
Please attach the file again and post your software version.
Farrukh
Farrukh Haroon Tue, 12/16/2008 - 01:52
It seems you are facing some issue with attachments on netpro. Can you try using a different browser, maybe that will help.
Farrukh
m.belateche Thu, 12/18/2008 - 04:51
I have uploaded the diagnostic information, please check the attached word file.
krir Thu, 12/18/2008 - 05:54
  • Cisco Employee,
I am neither able to view the file nor download it. Please paste the output of RAIDSTATUS instead of attaching it
m.belateche Sat, 12/20/2008 - 01:26
[pnadmin]$ model
mars110
local
extension
[pnadmin]$ pndbusage
Current partition started on Tue Dec 18 19:10:01 CET 2007 and uses 6.93% of its available capacity.
Switching to next partition is estimated for Tue Apr 19 14:00:51 CET 2022.
9 empty partitions are available for storage
[pnadmin]$ raidstatus
Adapter Information:
Product Name : Intel(R) RAID Controller SROMBSAS18E
Firmware Version : 1.03.00-0211
BIOS Version : MT30
Adapter RaidType Status Stripe Size Cache
a0 Raid-10 Degraded 64kB 1427649MB Enabled
PD Status Size & Block Model Serial#
p0 Unconfigured(good) 476940MB [0x3a386030 Sectors] ATA ST3500630NS K 9QG0SASJThis Drive IsForeign.
p1 Online 476940MB [0x3a386030 Sectors] ATA ST3500630NS K 9QG0SA5M
p2 Online 476940MB [0x3a386030 Sectors] ATA ST3500630NS K 9QG69XW1
p3 Online 476940MB [0x3a386030 Sectors] ATA ST3500630NS K 9QG0QTT9
p4 Unconfigured(good) 476940MB [0x3a386030 Sectors] ATA ST3500630NS K 9QG0H8R3This Drive IsForeign.
p5 Online 476940MB [0x3a386030 Sectors] ATA ST3500630NS K 9QG677HW
Farrukh Haroon Sat, 12/20/2008 - 01:52
If I were you, I would re-image the box if possible to regroup the RAID drives. This is the Cisco description for this error:
"The serial number of the physical HDD.
The string, "This drive is foreign" is appended to the serial number when an HDD formatted with metadata from a different RAID controller is introduced. The message is removed when the HDD is assimilated into the array. "
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/hardware/installation/guide/maintain_gen2.html
(Table 5-3)
Farrukh
