ASA Remote VPN DHCP or Address Pool
Dec 15th, 2008
I am running a pair of 5520 ASA devices in a load balancing configuration. I have multiple Remote VPN groups using these boxes and would like to use DHCP to hand out an IP address to all the groups but one. However, in the group configuration window for assigning IP addresses it says the change is a global change and not just for the group. The choices are Authentication Server, DHCP, or IP Address pool. The box will cycle through the choices until an address is found. Is there a way to configure a group to use an IP Address pool while all other groups are on DHCP. As I understand it the DHCP rule will be used before the IP address pool globally. Thanks for your ideas.
