configuration copy using SNMP doesn't work on cat os 8.4(11)GLX
Dec 15th, 2008
Hello together,
we use ca spectrum to manage our network infrastructure. We also store the configs of our cisco switches with spectrum via snmp.
This config copy via snmp works fine with all but the cat os 8.4.11(GLX) switches. Spectrum uses the CISCO-CONFIG-COPY-MIB to download the config of these switches but this doesn't work.
Does anybody know what could be the reason for this problem?
Best Regards,
Thorsten Steffen
Joe Clarke Mon, 12/15/2008 - 09:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The CISCO-CONFIG-COPY-MIB is supported in this version of CatOS, and copy operations should work. What exactly is Spectrum doing, and what errors does the switch return? A sniffer trace of the operation would be helpful to see.
thorsten.steffen Wed, 12/17/2008 - 23:10
attached you find the set request and the get response of an unsuccessful attempt to get the config of a 8.4.11(GLX) CatOS switch.
Best Regards,
Thorsten Steffen
Joe Clarke Wed, 12/17/2008 - 23:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What type of switch is this?
thorsten.steffen Wed, 12/17/2008 - 23:33
WS-C4003 Software, Version NmpSW: 8.4(11)GLX
Copyright (c) 1995-2006 by Cisco Systems, Inc.
NMP S/W compiled on Apr 27 2006, 12:44:02
GSP S/W compiled on Apr 27 2006, 11:47:52
System Bootstrap Version: 6.1(5)
Hardware Version: 2.7 Model: WS-C4003 Serial #: JAE07361CRD
Mod Port Model Serial # Versions
1 0 WS-X4012 JAE07361CRD Hw : 2.7
Gsp: 8.4(11.0)
Nmp: 8.4(11)GLX
2 48 WS-X4448-GB-RJ45 JAB073505ZB Hw : 1.1
3 6 WS-X4306-GB JAE07382HT9 Hw : 2.2
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 36947K 28589K 12288K 5848K 6440K 480K 323K 157K
Joe Clarke Thu, 12/18/2008 - 09:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
That's the problem. The CISCO-CONFIG-COPY-MIB is not supported on the Cat4K. It is only available on the Cat6K in 8.4 code. You will need to use the CISCO-STACK-MIB on the Cat4K to copy the configuration.
