configure exceptions from Webauthentication
Dec 15th, 2008
is there a possibility to use a single SSID for guest access using primarily Webauthentication and adding exception for certain ip addresses or URL's so that a connection to e.g. or a VPN gateway can be established without authentication but everything else needs authentication? We are using 4402 controllers with sw version
p.blakeway Mon, 12/15/2008 - 13:53
you should be able to use a pre-authentication ACL for this very task. iirc create an ACL in security then apply ACL in the web authetication.
amadeus Tue, 12/16/2008 - 00:52
i set up the follwoing ACL and applied it to the webauthentication preauthentication ACL:
(MUCWCO04) >show acl detailed "No authentication"
1 Out Any 0-65535 0-65535 Any Permit 0
2 In Any 0-65535 0-65535 Any Permit 0
DenyCounter : 2037
but if i try to ping it's not working and i just see the deny counters increasing. As soon as i log in as guest user it's working fine. Is there anything wrong on the ACL?
amadeus Mon, 01/05/2009 - 04:46
i just mixed up inbound and outbound. It's working fine now.
Trending Topics - Security & Network
