12-15-2008 08:45 AM - edited 03-15-2019 03:05 PM
Can somebody advice me what servicse shouldn't I run on all servers? Forexample Extension mobility feature I don't use - so I should use it. What else?
12-15-2008 08:58 AM
that completely depends on what you want to have, so the question is:
what features you want??????
java
if this helps, please rate
12-15-2008 10:22 AM
The services that I want:
Call proccesing,
conferencing,
TFTP,
web dialer,
CTI services (have IPCC integrated)
so thats all
As I understood I answered for my qeustion?
What about DHCP service on CUCM? Should I stop it if I use external DHCP?
Also I think I can stop CAR, beacause I didn't
use it.
CDR should be enebled ofcourse.
12-15-2008 10:30 AM
well my friend, seems you're answering your own question =)
if you're using an external DHCP there is no reason to leave the service running on CUCM also if using just CDR but no CAR there is no reason to leave them running
you need IPVMS for conferencing
java
