CUCM 6.1.2.1002-1 - Problems adding SNMP destination
Answered Question
Dec 15th, 2008
I'm trying to add an SNMP destination to a CUCM server. I get to the step where it asks you to choose a community string, but it doesn't list any of the strings in the system in the dropdown menu. If I try to add a new one though the destination page, it adds it but when it comes back to the notification page the new one still isn't in the dropdown menu. Screenshot attached shows what I mean if I wasn't clear. Has anyone run into this?
Correct Answer by Jaime Valencia about 8 years 3 months ago
Only community strings with minimum notify privileges (ReadWriteNotify or Notify Only) display. If you have not configured a community string with these privileges, no options appear in the drop-down list box.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 12/15/2008 - 09:54
  • Cisco Employee,
  • Hall of Fame,
    2011
java
