CUCM event/system/application Logs
Dec 15th, 2008
Our phones are rebooted just now. When I login to the CUCM, all of the phones are already registered normally.
How can i get the logs on what has been happening, like event, system, or application logs.
Thank you
Jaime Valencia Mon, 12/15/2008 - 09:53
since there is no version i will assume a linux appliance, use RTMT to pull the logs.
if windows simply open the event viewer
java
if this helps, please rate
