OID to track Config Change on PIX, ASA & FWSM
Dec 15th, 2008
Our End customer is trying to find OID using which Last Config Changes can be Tracked.
Is there any OID that records Config change revision number or any such information.
cisco24x7 Mon, 12/15/2008 - 10:40
You are making a easy problem much more
complicated than it appears to be.
This can be easily done with RANCID.
vijay sanwal Mon, 12/15/2008 - 10:45
Thanx for your valuable suggestion. I will definately discuss this with our customer.
But the original request is somewhat similar to MIB - CISCO-CONFIG-MAN-MIB. But this seems to be working only for Switches and not PIX/ASA and FWSM.
