12-15-2008 11:38 AM - edited 02-21-2020 03:10 AM
I'm transitioning from a Netscreen 50 to an ASA 5510. Trying to re-establish the few VPN tunnels that I have. On the old Netscreen, rather then using a IP address for the far end of the tunnel, it uses a "PeerID" (the other end of the tunnel gets it's IP address DHCP from comcast). Is this functionality available in ASDM? When I run the VPN Wizard, I don't see an option for it, only for IP address. Don't want to use an IP, because it can and does change often.
Thanks!
Solved! Go to Solution.
12-15-2008 12:11 PM
Daniel
Yes this functionality is available with the ASA, it is called dynamic crypto maps. Have a look at the following configuration guide and if you still have questions don't hesitate to come back -
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/ike.html#wp1042880
Jon
12-15-2008 02:31 PM
Daniel
With a dynamic crypto map the only "identifier" as such is the pre-shared key. With a dynamic crypto map any IP address can attempt a connection to the VPN device but obviously without the pre-shared key it will not authenticate and set up a tunnel.
Hence the security of the tunnel is even more reliant on the pre-shared key.
Jon
12-15-2008 12:11 PM
Daniel
Jon
12-15-2008 01:56 PM
Jon,
I think I understand what's going on here, except for one thing:
The crypto map (not dynamic) uses the peer ip address and pre-shared key to authenticate the peer. I have this for the peer:
(123 is my example peer IP Address)
crypto map Outside_map 20 set peer 123.123.123.123
what other identifier would I use with the dynamic crypto map to identify the peer (since I'm not going to use the IP)?
Thanks for your patience :)
12-15-2008 02:31 PM
Daniel
Jon
12-15-2008 04:35 PM
Jon,
Well, I suppose that would make sense! As always, thanks for helping the newbie :)
--Dan
