Exchange 2007 CCR Cluster on Win 2008
Dec 15th, 2008
  • Silver, 250 points or more
We have to do a pull because the SNARE agent is incompatible with Win 2008. Do we pull from the physical ip address or the Virtual ip address?
What would make this complicated if the Virtual ip were to be used is that the Virtual ip varies. It is a cluster which spans two networks for disaster recovery and site resiliency, a very slick new feature in Exchange 2007.
Thanks.
Farrukh Haroon Mon, 12/15/2008 - 22:55
  • Red, 2250 points or more
I thought the virtual IP address by virtue of being 'virtual' should not change? :)
I guess it makes more sense to add the Virtual IPs. You can even add multiple hosts (with different IPs).
Farrukh
