Lan to Lan tunnel between Juniper SSG5 and Cisco 3005 concentrator
Dec 15th, 2008
Does anyone have a configuration example?
or have you successfully established a tunnel between these two devices? or between SSG5 and Cisco ASA 5520?
Overall Rating: 3 (1 ratings)
ajagadee Mon, 12/15/2008 - 19:47
  • Cisco Employee,
Thomas,
Since, both the devices support the IPSEC RFC, you should be able to build the ipsec tunnel between them.
Below is a URL that has information on Configuring IPSec LAN-to-LAN tunnel between the Cisco Pix Firewall and a NetScreen Firewall. Eventhough, this is for a Pix, it should help you on the Netscreen side. Also, below is another URL between Pix and VPN3000. By comparing both the URLs you should be able to build a tunnel between the VPN3000 and Netscreen.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801c4445.shtml
LAN-to-LAN IPSec Tunnel Between the Cisco VPN 3000 Concentrator and PIX Firewall Configuration Example
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00800949d2.shtml
Arul
*Pls rate if it helps*
thomuff Tue, 12/16/2008 - 13:55
We figured it out. Local Network configuration was not matching SSG configuration. Thanks for your reply.
