Jon Marshall Mon, 12/15/2008 - 12:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Brent
HSRP relies on L2 adjacency ie. the 2 devices must be connected with a layer 2 link. So in answer to your question, yes you can run HSRP between 2 locations as long as the 2 locations are connected with a L2 link and the same vlan is in both locations.
Whether or not you would want to is another matter ! What exactly is it you are trying to achieve ?
Jon
Brent Rockburn Mon, 12/15/2008 - 12:32
Hey Jon, thanks for the quick reply.
I have one site here where I am .. and the DR site is in a city to the south of us. We have a DS3 link between us and them. Our branch offices need to be able to hit the DR site in case our head office falls off the map.
Jon Marshall Mon, 12/15/2008 - 12:49
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay, setting up a DR site can be quite a complex scenario and we would need to understand your topology/routing protocols/IP addressing etc. to suggest a solution.
HSRP will not work across a L3 routed link only a switched L2 link.
Jon
Brent Rockburn Mon, 12/15/2008 - 12:51
Hey Jon,
Thanks, I know I'm not giving you much in the way of info .. sorry about that.. but I do believe you've answered my question. The routers wouldn't be on the same L2 segment so I don't think this would work.
