Huge amount of Total output drops
burleyman
Level 8
Level 8
I am seeing the "Total output drops" and "txload" go up. What should I look at for this. I do not see any other errors?
GigabitEthernet1/2/42 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0011.9299.bb49 (bia 0011.9299.bb49)
Description: ROC80 (62)
MTU 9216 bytes, BW 100000 Kbit, DLY 10 usec,
reliability 255/255, txload 17/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseT
input flow-control is off, output flow-control is off
Clock mode is auto
Last input never, output 00:00:02, output hang never
Last clearing of "show interface" counters 01:43:13
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 1306379
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 6721000 bits/sec, 878 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
5117480 packets output, 4758857198 bytes, 0 underruns
Mike
10 Replies 10
glen.grant
Make sure the speed and duplex are set exactly the same on both ends of that link , if one end is hardcoded and the other is auto that can cause problems . Check to make sure both ends are set up for giant packets also as I see the mtu size is 9216 .
I will check that but wouldn't I see other errors if the speed and duplex were different? I will also check the giant packets on both sides.
Mike
I think I may have found the problem. Correct me if I am wrong...
If I Team two NIC's in a server I have to setup the switchports in an ether-channel....correct?
Mike
Joseph W. Doherty
What you might "look at" is what type of traffic is passing across this interface. Assuming your counters are correct, a 25% drop percentage may indicate insufficient bandwidth for non-TCP traffic or such traffic is very bursty. If the latter, increasing the output queue size might help (or use WRED, not for early drop, but for its average queue size feature).
I will check all that. What is WRED? Also it might be bursty as I keep checking it and it stays the same for about 30 seconds and then it increments up and stays again....
ROC-6509-VSS#show int gi1/2/42 | inc txload|Total output drops
reliability 255/255, txload 14/255, rxload 1/255
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 1852644
reliability 255/255, txload 15/255, rxload 1/255
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 1852716
See how it went up.
Mike
Thanks. I will check that out.
Mike
Output drops are caused because the hardware queue can't send the packet. Meaning you might have a performance issue or a buffer issue somewhere.
Most of the time these errors occur on interfaces connected to routers because the output speed is usually much slower than the input speed, for example 100Mb Ethernet LAN and only a 2Mb WAN link.
If this is a server is the server nic setup to handle giant packets ?
Yes it had that setup. I did find an issue with the NIC and how teaming and etherchanneling was setup. I am going to update the NIC driver and make some needed configuration changes after the 1st of the year. Right now I disabled the NIC and the output errors went away.
Mike
