Time dumps as meaningless string
Dec 15th, 2008
Good day.
I am attempting to perform a dump for the purpose of creating information for my administrators to view.
For the most part the data is usefull with the exception of the following item ... Time ...
Example One: dateTimeOrigination = 1204373710
Example Two: dateTimeOrigination = 1209479575
Example Three: dateTimeConnect = 1209479575
Example Four: dateTimeDisconnect = 1209479638
I have tried every cipher / algorithm I can think of ... can any of you please tell me how to translate these useless numeric strings into meaningful data?
Thank you for your time
MV_Agusta
MV_Agusta Mon, 12/15/2008 - 15:19
Thank you.
I greatly appreciate the information. Any code is easily understood once you know the standard upon which the code is based.
Having been given that information I shall be able to conduct all work neccesary.
Your time is appreciated
MV_Agusta
Jaime Valencia Mon, 12/15/2008 - 15:23
  • Cisco Employee,
  • Hall of Fame,
    2011
you're welcome
the file i attached contains the formula, of course you need to do the necessary correction to adjust the timezone since that converts time to GMT 0.
just adjust +- X seconds to do that depending on timezone
java
if this helps, please rate
