Stickyness based on pattern match
Trying to replicate a Radware load balancing setup - where a string is searched for in the HTTP header, then the following field (by offset) is used as the cookie.
There doesn't seem a way to do similar on ACE, the field is too far into the header to reliably find it by offset alone.
Have you tried type "generic"? For example:
sticky layer4-payload WHATEVER
layer4-payload yada yada yada
serverfarm SFARM-WHATEVER
policy-map type loadbalance generic first-match LB-POLICY
class class-default
sticky-serverfarm WHATEVER
Cathy
With Layer 4 payload stickiness (
stickiness based on a string in the data of a TCP stream or UDP packet) you can stick sessions using any string
details at
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/sticky.html#wp1064423
Syed Iftekhar Ahmed
Thanks, had figured that out by the time you replied.
Has anyone got any configuration examples? Configuring the 'sticky layer4-payload' part is fine, but when it comes to applying the policy I get 'Error: Sticky type not consistent with policy map type' - despite trying various different policy types.
class class-default
Cathy
Thanks, 'generic' was the keyword I was missing.
