tacacs-server limit
Answered Question
Dec 15th, 2008
I have a quick question for you...is there a limit on how many tacacs-server I can have on a router? I mean currently I have:
tacacs-server host 192.168.11.10 single-conneciton
tacacs-server host 192.168.21.53 single-conneciton
can I add another one without killing anything?
tacacs-server host 192.168.51.27 single-conneciton
Correct Answer by ajagadee about 8 years 6 months ago
Warren,
Yes, adding the .27 server to the already existing list of TACACS Server will not kill anything. You can use multiple tacacs-server host commands to specify additional hosts. The Cisco IOS software searches for hosts in the order in which you specify them.
http://www.cisco.com/en/US/docs/ios/12_3/security/command/reference/sec_s1g.html#wp1100025
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Wed, 12/17/2008 - 09:04
  • Cisco Employee,
Warren,
Arul
wgranada1 Wed, 12/17/2008 - 09:25
great!!!! thanks Arul for the info and for the link this helps alot...thank you!!!!
