PIMG Upgrade Version Question
Answered Question
Dec 15th, 2008
I want to get the PIMG to the latest code. It is currently running 5.1.139n from 8/11/2007. 5.1su3 is the target.
When i dwnld and extract the files for the uprade they are:
ami_5.1.139N.fsh
ami_5.1.155.2N.app
iNim60.ibt
iNim190.ilc
iNim653.iap
run_910FskEcho.dsp
Is this correct? Obviously my concern is the extracted file ami_5.1.139N.fsh - this is the version we want to move from.
Correct Answer by culittle about 8 years 7 months ago
thanks,
can you please rate if this resolved your issue?
Overall Rating: 5 (1 ratings)
culittle Tue, 12/16/2008 - 06:19
  • Cisco Employee,
You are correct. That is the version you want to move to. It just takes a couple of minutes. Export your config.ini and you are ready to upgrade.
5.1.139N is su2
johnnywan Tue, 12/16/2008 - 06:24
Thank you for the response. Just to make sure, I should not be concerned that i see the ami_5.1.139N.fsh file in the extraced files? Like i said, that is the version we are trying to move from. Thanks again.
culittle Tue, 12/16/2008 - 06:49
  • Cisco Employee,
You are currently running su2. You are trying to upgrade to su3.
Correct Answer
culittle Tue, 12/16/2008 - 08:47
  • Cisco Employee,
thanks,
