about registered CTI port and RTMT
Dec 15th, 2008
I need to find out the number of registered CTI port on the call manager, I am trying to use the Real time monitoring tool at the moment. I go to "CTI" then "CTI Manager" ....then it show the NumOfOpenDevices and NumofOpenLines .,....whats the difference between them?
where can I find the number of registered CTI port on call manager via the RTMT?
kind regards
Rachel
aniramac Thu, 09/13/2012 - 17:54
Using CTI terminology, a registered device is an "Opened" device.
Thus, you can check here:
RTMT > CallManager > CTI > CTI Search > CTI Devices
Select the CTIManager which your CTI Application is using as a CTI Provider.
Select Devices Status as "Opened".
Key in the other parameters as you require.
