Holiday Greeting
Answered Question
Dec 15th, 2008
Hi Everyone
I have a question about the holiday greeting, I have a standard greeting for offhours and regular holidays but I need to make a neew one just for this holiday, how can I just change the recording of the standard greeting so i dont have to make a new one, I have the wave file to replace it but i don't seem to find it.
Any help will be greatly appreciated
Luis
Correct Answer by Bradford Magnani about 8 years 2 months ago
Yep, in the X:\Commserver\StreamFiles directory
Hope this helps, if so please rate.
Brad
Overall Rating: 5 (1 ratings)
j.mccartney Tue, 12/16/2008 - 06:40
You can also go into the alternate greeting of the mailbox you want and record a greeting. Then activate the alternate greeting; the alternate takes priority over standard and closed. HTH's
luisrolocq Tue, 12/16/2008 - 16:02
Thanks Brad
It worked, do you know by any chance where the wav files are been stored?
Correct Answer
Bradford Magnani Tue, 12/16/2008 - 16:30
Brad
