No tunnel group passwords inside ASA backup
Answered Question
Dec 15th, 2008
Hi Does anyone know why the tunnel group passwords have been removed from the config. See below
tunnel-group TG_RAS ipsec-attributes
pre-shared-key *
This means that if I try to restore the config I am going to have an * as the preshare key password.
Is there a way to have the preshare key shown as encrypted text?
Many thanks
Correct Answer by Farrukh Haroon about 8 years 1 month ago
They are not removed. This is more of a security feature to evade the 'over the back' peekers :). You can see/recover the password using multiple ways:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00807f2d37.shtml
Farrukh
Correct Answer by JORGE RODRIGUEZ about 8 years 1 month ago
In addition you can also issue more system to show secret keys in plain text of all Ipsec tunnels preshare keys.
The password has not been removed, as far as I know they do show as * but the actual password is there, when you backup config that information will be backed and copied back to fw when restoring config.
asa#more system:running-config
Correct Answer by ajagadee about 8 years 1 month ago
Do a "write net tftp_server_ip:filename" and then open the filename from the tftp server. It should be in a non-encrypted format. The encryption is caused by the PIX software.
Arul
*Pls rate if it helps*
Overall Rating: 5 (3 ratings)
Correct Answer
ajagadee Mon, 12/15/2008 - 20:07
Arul
Correct Answer
JORGE RODRIGUEZ Mon, 12/15/2008 - 20:57
