STP or HSRP problem
Dec 16th, 2008
Hi NetPro,
anyone who has the experience about the below logs ? i have configured the root bridge to the switch and HSRP configured as well.
Dec 12 15:40:24.556 CCT: %STANDBY-6-STATECHANGE: Vlan10 Group 1 state Standby -> Active
Dec 12 15:40:24.564 CCT: %STANDBY-6-STATECHANGE: Vlan10 Group 1 state Active -> Speak
your reply will be highly appreciated.
thanks.
regards,
jack
Overall Rating: 2.9 (9 ratings)
Giuseppe Larosa Tue, 12/16/2008 - 02:09
  • Hall of Fame,
    Founding Member
Hello Jack,
the local router has changed state from standby to active because it has missed three HSRP hellos from neighbor.
Then it receives again a better hello from the neighbor and it reverts to non active state
This can be seen sometimes for different reasons: the neighbor router cpu is high or the link is full. or the neighbor interface has flapped
Hope to help
Giuseppe
lamav Tue, 12/16/2008 - 02:10
  • Blue, 1500 points or more
Jack, it means that the routers running HSRP for this vlan experienced a change in state. The standby router went active, and then to speak.
Did the other router in the HSRP group fail? Is tracking enabled on an interface that may have gone down? Was another router added to the HSRP group?
Victor
ney25 Tue, 12/16/2008 - 02:52
Hi Victor,
both switches in the hsrp group. but, funny thing is only switch 1 had this logs . whereby sw 2 not even received any fail msg.
Giuseppe Larosa Tue, 12/16/2008 - 03:03
  • Hall of Fame,
    Founding Member
Hello Jack,
this means that only the local missed the other's switch hellos
no link faiure on the other device.
check the incoming traffic volume and if you have input errors of any type
Hope to help
Giuseppe
ney25 Tue, 12/16/2008 - 03:15
Hi Qiuslar,
thanks for your information, what can i do after checking the input traffic volume ?
this logs show on the vlan10 having the flapping from Active->Standby.
your information will be helping me a lots.
thanks.
regards,
jack
viyuan700 Tue, 12/16/2008 - 05:49
  • Silver, 250 points or more
This HSRP member has changed from standby to active (means this was standby other was active), So if this is also active now can you check are both active for vlan 10?
If only one is active and one is standby for vlan 10 then you have just missed the error message on other switch.
Do you have only vlan 10 here or there are more vlan?
ney25 Tue, 12/16/2008 - 06:16
hi viyuan,
yes, this switch only contained 3 vlans (vlan 10, 20 and 30).
so, only sw 1 had received the Active->Standby logs. sw 2 has no suspicious logs shown.
so, now the sw 1 is standby and sw 2 is active.
thanks.
regards,
jack
viyuan700 Tue, 12/16/2008 - 23:46
"These error messages describe a situation in which a standby HSRP router did not receive three successive HSRP hello packets from its HSRP peer. The output shows that the standby router moves from the standby state to the active state. Shortly thereafter, the router returns to the standby state. Unless this error message occurs during the initial installation, an HSRP issue probably does not cause the error message. The error messages signify the loss of HSRP hellos between the peers. When you troubleshoot this issue, you must verify the communication between the HSRP peers. A random, momentary loss of data communication between the peers is the most common problem that results in these messages. HSRP state changes are often due to High CPU Utilization. If the error message is due to high CPU utilization, put a sniffer on the network and the trace the system that causes the high CPU utilization.
There are several possible causes for the loss of HSRP packets between the peers. The most common problems are physical layer problems or excessive network traffic caused by spanning tree issues"
These error messages can be due to high CPU utilization or physical/spanning tree problem.
U can check CPU utilization?
What to check in physical problem see this link
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml#t26
ney25 Wed, 12/17/2008 - 19:16
Hi Viyuan,
thanks for your information.
below is my sw config.
sw 1:
Vlan10 - Group 1
Local state is Standby, priority 90, may preempt
Hellotime 3 sec, holdtime 10 sec
Next hello sent in 2.394
Virtual IP address is 192.168.29.1 configured
Active router is 192.168.29.3, priority 100 expires in 8.072
Standby router is local
193 state changes, last state change 5d19h
IP redundancy name is "hsrp-Vl10-1" (default)
Vlan20 - Group 2
Next hello sent in 1.910
Virtual IP address is 192.168.30.252 configured
Active router is 192.168.30.254, priority 100 expires in 7.804
130 state changes, last state change 23:44:00
IP redundancy name is "hsrp-Vl20-2" (default)
Sw 2:
Vlan10 - Group 1
Local state is Active, priority 100, may preempt
Next hello sent in 2.588
Active router is local
Standby router is 192.168.29.2 expires in 8.288
Virtual mac address is 0000.0c07.ac01
23 state changes, last state change 1y1w
Vlan20 - Group 2
Next hello sent in 1.536
Standby router is 192.168.30.253 expires in 9.752
Virtual mac address is 0000.0c07.ac02
17 state changes, last state change 1y1w
thanks.
regards,
jack
viyuan700 Wed, 12/17/2008 - 21:57
sw 1:
Sw2
Your switch 1 is changing state too much, can you check the followiong command for Sw1
show interface vlan10
show interface vlan20
show processes cpu
show ip interface brief
Also check the interface for errors to which this Sw1 is connected
ney25 Wed, 12/17/2008 - 22:35
Hi viyuan,
as requested. sw 1 config as below.
Vlan10 is up, line protocol is up
Hardware is Ethernet SVI, address is 0012.00f4.0f3f (bia 0012.00f4.0f3f)
Internet address is 192.168.29.2/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 3 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
L3 in Switched: ucast: 260886453 pkt, 61897410344 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 126079495 pkt, 73856057436 bytes - mcast: 0 pkt, 0 bytes
278729315 packets input, 64051007405 bytes, 0 no buffer
Received 17842862 broadcasts (66184 IP multicast)
250976519 packets output, 96033769983 bytes, 0 underruns
0 output errors, 0 interface resets
Vlan20 is up, line protocol is up
Internet address is 192.168.30.253/24
L3 in Switched: ucast: 127517032 pkt, 74021215211 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 117686801 pkt, 36920089185 bytes - mcast: 0 pkt, 0 bytes
127517032 packets input, 74021215211 bytes, 0 no buffer
Received 0 broadcasts (34781289 IP multicast)
165793313 packets output, 41477436208 bytes, 0 underruns
CPU utilization for five seconds: 6%/0%; one minute: 6%; five minutes: 8%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
27 10260104001515314164 677 3.11% 2.58% 2.73% 0 Cat4k Mgmt HiPri
28 13514389242215706604 0 1.75% 3.19% 4.87% 0 Cat4k Mgmt LoPri
45 64846364 61693175 1051 0.39% 0.30% 0.27% 0 CDP Protocol
82 19490452 103660725 188 0.39% 0.03% 0.02% 0 IP SNMP
46 92 166 554 0.15% 0.07% 0.02% 1 Virtual Exec
38 14573036 95319458 152 0.07% 0.14% 0.10% 0 Spanning Tree
and i dont see any error on the sh ip int bri.
thanks.
regards,
jack
viyuan700 Wed, 12/17/2008 - 22:45
Vlan10 was changed 5d19h before
vlan20was changed nearly a day before.
Stable at this moment. Looks like you have to log CPU utilization high or errors when HSRP state change to troubleshoot it.
ney25 Wed, 12/17/2008 - 22:52
i just curious, vlan 10 and 20 were using for years, nobody has changed the configuration.
any possibilities reason ?
viyuan700 Wed, 12/17/2008 - 23:24
Can't tell what is going on? Why sw1 is missing hello packets after 4-5 days suddenly and then normal. Maybe u can further investigate is something happening on sw1 ?
Your sw2 has changed state an year before. Pretty stable
ney25 Wed, 12/17/2008 - 23:46
hi viyuan.
regards,
jack
