ACE context syslog
Answered Question
Dec 16th, 2008
Hi!
Does someone know how to configure the syslog under a context?
The syslog should be send via public interface. No additional management interface should be configured.
Any ideas?
Correct Answer by dario.didio about 8 years 1 month ago
Can you configure for example:
logging trap 6
This specifies that messages between 0-6 are send to the syslog server specified by the "logging host" command.
I don't know which severity is the default value.
Overall Rating: 5 (1 ratings)
dario.didio Tue, 12/16/2008 - 04:40
you can configure syslog under each context separatly.
Please refer to following document.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/configuration/system/message/guide/config.html#wp1059844
Normally, the ACE will use its public interface due to its routing table (default route is pointing to public interface)
Hope this helps!
celiocarreto Tue, 12/16/2008 - 05:13
I configured it as described in the manual.
In the Admin context it works. In a sub-context not. No Packets are sent by the ACE appliance.
Any other ideas or working configurations?
dario.didio Tue, 12/16/2008 - 05:17
I'm using it in different contexts and it works fine.
can you upload your config?
celiocarreto Tue, 12/16/2008 - 05:58
The configuration is basicly:
logging enable
logging fastpath
logging console 1
logging timestamp
logging buffered 5
logging persistent 6
logging monitor 5
logging facility 21
logging queue 1024
logging device-id context-name
logging host 195.122.17.210 udp/514
logging rate-limit 42 60 level 5
logging rate-limit 42 60 level 6
logging rate-limit 42 60 level 7
access-list V101-IN line 1 extended permit icmp 195.122.1.0 255.255.255.0 195.
access-list V101-IN line 2 extended permit icmp any host 195.122.1.6
access-list V101-IN line 3 extended permit icmp any host 195.122.1.5
access-list V101-IN line 10 extended permit icmp any host 195.122.1.17
access-list V101-IN line 20 extended permit icmp any host 195.122.1.18
access-list V101-IN line 30 extended permit icmp any host 195.122.1.19
access-list V101-IN line 40 extended permit tcp any host 195.122.1.17 eq www
access-list V101-IN line 50 extended permit tcp any host 195.122.1.18 eq www
access-list V101-IN line 60 extended permit tcp any host 195.122.1.19 eq www
access-list V101-IN line 68 extended permit tcp any host 195.122.1.17 eq https
interface vlan 3
description WL-Server-Frontend
ip address 10.125.145.253 255.255.255.0
alias 10.125.145.254 255.255.255.0
peer ip address 10.125.145.252 255.255.255.0
service-policy input ICMP-ALLOW
no shutdown
interface vlan 101
description outside
ip address 195.122.1.5 255.255.255.0
alias 195.122.1.6 255.255.255.0
peer ip address 195.122.1.4 255.255.255.0
access-group input V101-IN
service-policy input L4-V101-LB
no shutdown
ip route 0.0.0.0 0.0.0.0 195.122.1.1
Correct Answer
dario.didio Tue, 12/16/2008 - 06:09
logging trap 6
